Bcpr7es so should be .9mm. When the pipe blew off I had Bcpr6es-11 plugs in so 1.1mm gap. I was advised by some people at work and reading online that turbo motors don't like big spark gap hence changeing to smaller gap and also run a cooler plug but from what I've read that is more for higher boost applications(which I plan on doing later down the track)
Did you check before fitting?
blew the pipe off the turbo? which pipe, did it backfire or something? has it damaged the compressor on the turbo somehow ?
Yeah pipe coming off the turbo going to intercooler. Possibly? Anyway to tell rather than removing turbo?
Running rough and Misfire sound like a sensor to me, maybe plugs but all you will need to do on one of these flash 'Ingected' things is plug in your OBDII and read the codes
Ha! Na mate no OBDII on this oldschool Nissan efi. The ecu does have a diagnostic mode on it which I tried last night and if I did it correctly came up with code 13 coolant temp sensor, code 34 knock sensor and code 43 tps sensor.... BUT I could be wrong
TPS and knock sensor are interesting.
Coolant one could explain cold running, have you checked the connection?
I've unplugged it while running and plugged it back in which didn't seem to make a difference either way. The plug itself is a bit damaged but I still believe it is making contact. I've check resistance while warm on temp sensor and got 0.3 with multimeter set to 20k ohms. Haven't checked it cold yet
