Mixing crown wheels and pinions is usually a no no, they tend not to last very long.
Fair enough, was just looking for a short cut, but I'll do it the right way [emoji106]
Good grief no.
The gear sets are matched.
You gotta swap the crownwheel from your long nose diff onto your LSD nugget.
How easy is it to turn the inputs opposite directions?
You gotta lever the out with a big bar. The clips which hold them in can hang on tight some times.
If it's really easy to spin them opposite directions, it might be a candidate for the Dr Joesf Mengele of diffs to do some "experiments" on......
Alright definitely not swapping ring gears between diffs. Yeah it was rather easy which sucks... I've talked to James today and we are gonnaa have a diff day soon
You could reuse the center out of your 4.3 if it's tighter.
I want to get my hands on a cooked viscous center.
The idea was so I could just swap housings over instead of pulling the insides out and having the car off the road longer.. plus I spent a fair bit getting this other shortnose lsd...
Bart and I are both Keen to learn how to put new Viscious fluid into a worn out one
Greg, can you confirm what im seeing in the photo's
Is the Fat 8mm Spacer shim on the same side on BOTH the short nose & Long nose ?
I'll check tonight
Couldn't get in the garage last night... door wouldn't open hoping new batteries in the remote solves the issue as there is no other way to get in...
