Now you were probably all hanging out for an update on the diff over the weekend. Thought I'd make you all wait another day.
Successful day out in Rangiora on Saturday at James' place. Pressed the new pinion bearings on the pinion shaft and pressed the outer bearing races into the diff housing. Once that was done we fitted the pinion into the housing and cranked the pinion flange nut up a bit to get everything to seat properly. Fitted the crown wheel to the VLSD center and installed. To start with we just used the shims that came out of the diff when I removed the locked center. Checked backlash and needed a slightly thicker shim to get it right. I brought the shortnose housing with me and I can't quite remember if it was a shim from that diff we used or one from James' stock but it's all set up now! Gave the housing a coat of VHT gloss black engine enamel and baked it on with James' gas torch. Fitted the new side seals and decided to call it a day.
Now James wasn't happy with the surface on the pinion flange, you can see a score mark that goes all around the diameter of the flange. James reckons I should get a speedi sleeve to go over the flange to protect the seal or use the pinion flange that's on the other diff but I don't know what sort of condition that is in yet... interested to hear your thoughts.
Removed the pinion flange today and fitted new pinion seal. Won't be putting a flange back on til I know what I'm doing (reuse one that came off or use the one on the other diff)
Got a whole bunch of stuff vapour blasted recently and man it looks good! So got the rear cover done, 2x R180 rear covers and some L series thermostat housings done. So clean! So with this diff I'm going to clear coat the cover, just need to get my heat gun back off a mate..
Going to have to haul ass and get this diff in this weekend as well replacing a leaking clutch slave and adjust clutch master. Should have all that done by next Thursday right??? Anyone else frantically getting ready for nats!?!?
