You can see the space I'm aiming to fit it into here. Hoses will be cramped, but I'll make it work somehow. Also if I ever do this again I'm going to use those weld on UN o-ring bosses, as it's damn hard to get the torch into the right spot when you have two male fittings side by side. Then welded this mounting strap on top. Still need to get an alloy fuel pump mount and weld it to this, then buy fuel pumps and start plumbing them in. Nabbed lots of R14 teflon hose before I left Hydraulink, so that should help keep costs down
