1200 coupe z18et project
- aka: The shed
Re: 1200 coupe z18et project
little bit of progress today, the radiator is fully mounted now too, and i just primered the radiator support bar today, and also took out the heater and got it working too! but i think i will POR15 the inside of the car before is put it back in!
1976 NA Lancer
1979 Starlet Bugeye
1974 ke25 coupe
1972 1200 coupe z18et
1979 Starlet Bugeye
1974 ke25 coupe
- aka: The shed
has been a bit of progress the last couple of days.
got around to painting the radiator support panel and the radiator mounts.
slapped on the inlet manifold.
soldered a new accelerator cable together as it needed to be a bit longer for the bigger throttle body.
put sound deadener inside the front of the car, got the stuff from supercheap and it is SUPER thick and goopey so hopefully it works well!
changed some leaky fuel lines the the back of the car.
wired up the heater properly which is my second to last wiring job on the car! (hopefully) now i just have to find a windscreen washer bottle and motor and put it somewhere and wire it up!
car is pretty much ready to start, tried the other night but stopped after i got fuel pressure because fuel was going everywhere haha!
I also found an electronic ignition book at work and it had my dizzy in it. I found that it is Variable Relucter type, not Hall or optical. and since RV is NOT square wave 12v signal (optical and Hall are square wave), i have to send back my computer to the megasquirt guy and get him to put another circuit in the ECU. but thats all good because then i wont be temped to start it and i'll work on other less fun stuff haha!
1976 NA Lancer
1979 Starlet Bugeye
1974 ke25 coupe
1979 Starlet Bugeye
1974 ke25 coupe
- aka: The shed
pics
1976 NA Lancer
1979 Starlet Bugeye
1974 ke25 coupe
1979 Starlet Bugeye
1974 ke25 coupe
- aka: J
^ thats soft core porn, its a semi naked behind.
and that looks MEAN as, you going to keep that camber on the rear?
- aka: The shed
haha cheers mate! unfortunately its not an independant rear end but i am planning to get the rear lowered quite a lot more so there is very little gay between the tyre and guard!DAT620 wrote:
1976 NA Lancer
1979 Starlet Bugeye
1974 ke25 coupe
1979 Starlet Bugeye
1974 ke25 coupe
- aka: The shed
done a few small things lately., fuel pump crapped out when i tried to start it so i am waiting for another one to show up.
Cert dude came by today. His name is Kendall Bradley. Is a real GC. i only have to put on a driveshaft loop, do something about the wheels sticking out of the guards, and tidy up the gearbox crossmember a little bit. then just make sure the brakes are up to the job and tidy little things up!
1976 NA Lancer
1979 Starlet Bugeye
1974 ke25 coupe
1979 Starlet Bugeye
1974 ke25 coupe
What fron struts does the car have in it atm?
- aka: The shed
I am 90% sure they are ones out of a S110 silvia.. but i dont really know what factory 1200 struts look like to compare. how come?
1976 NA Lancer
1979 Starlet Bugeye
1974 ke25 coupe
1979 Starlet Bugeye
1974 ke25 coupe
I can take a photo of the s110 struts, have 4 sitting here. PS if anyone wants/needs them, you can have a pair for like 30 bucks including brakes?
Would like to keep one set spare for the "just in case"
(sorry to kind of hi-jack your thread )
