1985 GB122 1200 Sunny Ute
buzzy
Datsun Driver
Re: 1985 GB122 1200 Sunny Ute
Post by buzzy »
definitely looks the goods at that height!
mint16
aka: Brendan
Post by mint16 »
Whats with the can?
Thats not the correct way to check vehicle ride height.
Tony_Whenua
Post by Tony_Whenua »
mint16 wrote:Whats with the can?
I don't follow...just thought that all structural parts minus the sump have to be above 100mm or do the bottom part of the leaf springs not count?
How do you measure the ride height? :?
DJZ
Post by DJZ »
Cellphone or with money between the wheel and arch.
Nissan 280ZX
Project thread
Other Nissan 280ZX
Project thread
2 doors
Post by 2 doors »
Im no expert, but I would think that the leafsprings would be included in that 100mm, from the pics it looks like your lowering blocks are the issue there, but if you use smaller ones you will effectively raise the ute, to save me going through your thread, are you trying to do this without cert? if so you will need to raise the rear, in this instance.
Tony_Whenua
2 doors wrote:Im no expert, but I would think that the leafsprings would be included in that 100mm, from the pics it looks like your lowering blocks are the issue there, but if you use smaller ones you will effectively raise the ute, to save me going through your thread, are you trying to do this without cert? if so you will need to raise the rear, in this instance.
Yeah I haven't touched the ass end. Its the set up from when I had 17s keeping me off the ground. Been looking up other ideas also but unsure about what will get me through a WOF without Cert.
Will look and flipping the rear leafs and then see what I have to remove off the blocks
Other option is put my sedan struts in and take the blocks out then get it a WOF as taking an inch out of the rear will prob make it look like I've tried to hot rod it.
mint16
aka: Brendan
Post by mint16 »
Ah my bad, I see what youve done there.
Reverse eye the rear leaves to counter act the height issue?
I think Ive gone anti-rules since leaving the AA as a wof inspector...
EMs SR1200 UTE
Regular
Post by EMs SR1200 UTE »
Had allways thought it was the chassis rail that had to be 100mm off the ground.......dont quote me tho.
S13 SR20 Datsun Roadster Ute
beaver
Post by beaver »
No^.
It is 100mm to the lowest structural point. However it seems what is seemed structural is up to the individual.
Tony, I had no trouble when I had those wheels and 2" lowering blocks, even got a VTNZ wof.
Tony_Whenua
beaver wrote:No^.
LOOKS LIKE IM OFF FOR A WOF ON SATURDAY!!! .... but were you at the same height?
