Page 16 of 21
Posted: Fri Sep 26, 2014 6:04 pm
Really? No push rod? Should have gone to Repco haha. I think I have a spare.
Posted: Fri Sep 26, 2014 6:06 pm
Hahahahahahaha na.... Legit man was just talking to Broke before and mentioned you might have one
Posted: Fri Sep 26, 2014 7:54 pm
I have pin punches too if need be.
Posted: Sat Sep 27, 2014 9:56 am
Got a 1.5mm pin punch?? Broke lent me his set but the smallest of his is 2.5mm not quite small enough
Started unbolting the gearbox last night, got stuck on one prick of a bolt by the firewall on the drivers side. Spent ages trying all sorts of ways to undo it. My mate is going to weld a 14mm ring spanner to some flatbar or some rod for max leverage.
Posted: Sat Sep 27, 2014 11:16 am
by cul8r
Greg, I used pretty much every 1/2" extension and run it parallel to the gearbox - I know what you mean - I took me a good few hours over a few days to do it, from memory John tried crows feet but was a prick of a position.
All of my extensions, plus a couple of Brocks, and ended up close to the driveshaft yoke, and it finally budged.
Posted: Sat Sep 27, 2014 12:44 pm
Hahaha yeah we tried heaps of extensions and universals but the unis were jamming and we couldn't turn it.
Posted: Sat Sep 27, 2014 2:13 pm
by brocky41
Also a good idea is to do two up tight around the culprit bolt - then crack that one first.
Posted: Sat Sep 27, 2014 5:33 pm
Ugh had another go this afternoon man it doesn't wanna budge!!!!! Spanners keep slipping off, we need to try a 6 sided socket as the ones we had all slipped off too
Even tried unbolting the crossmember to drop the motor down a bit but nope
Posted: Tue Sep 30, 2014 9:39 pm
Posted: Tue Sep 30, 2014 10:41 pm
by Ivan
Nice Greg.The manual will be a great upgrade.
