Page 16 of 17
Posted: Mon Jan 18, 2016 9:47 pm
by jeremiahnz
Yeah finally getting there after all these years. Check out my start motor post just today if you want to help with suggestions for possibly the final piece ;)
Posted: Wed Jan 20, 2016 12:24 pm
by Godzilladat
Holy shit!!!! :o
Posted: Mon Jan 25, 2016 6:56 pm
by jeremiahnz
This happened on the weekend:
Big thanks to taiparacer for helping me out with a starter motor to get this going.
It is running a Megasquirt 2 for fuel and timing, with the Megasquirt controlling a Pertronix dizzy (which is where it also gets signal). Found a few issues like the oil cooler has a massive leak, so a bit of work to do.
Posted: Mon Jan 25, 2016 8:14 pm
These run the early style H165 with the alloy center aye?
I wonder how strong those diffs are? Won't be long until you find out I'd say......... :burnout:
Posted: Wed Jan 27, 2016 4:07 pm
by jeremiahnz
I think the 411 was alloy centre and this one (410) steel or whatever. Maybe stronger but heavier??
Posted: Wed Jan 27, 2016 5:58 pm
by Kitch
wicked effort Jeremy!
Trust me I know what a milestone this is...
Great to stay on track with your plan to MSII & EFI the old girl.
Congrats, you will iron out the bugs in no time, and have this tuned running / driving
Posted: Wed Jan 27, 2016 6:38 pm
by jeremiahnz
Kitch wrote:wicked effort Jeremy!
Thanks kitch. Your build was a massive inspiration and mine is no where near yours! Will keep ironing out the bugs until I can send a pic of the car driving.
Posted: Thu Jan 28, 2016 5:01 pm
you are still supercharging it aye?
Posted: Thu Jan 28, 2016 8:54 pm
by jeremiahnz
Bartman wrote:you are still supercharging it aye?
Yep - definitely. The setup is ready to go together, I just need to get some supercharger oil and figure out how to switch the clutch with roughly a three second delay so it turns off at idle but doesn't turn off when changing gears. But it all bolts together etc.
Also I just wanted to make sure I could get it running with the simplest setup first, so one less thing to troubleshoot.
Posted: Thu Jan 28, 2016 9:25 pm
Is the TB before or after the super charger?
IMHO,
Before the blower is best.
If you wanna run it after the blower, run a micro switch to trigger the charger once the throttle reaches the off idle position. Otheriwse you close your TB, and the pump will blow your intercooler piping off.
