Page 17 of 17
Posted: Mon Feb 01, 2016 6:30 pm
by jeremiahnz
Bartman wrote:Is the TB before or after the super charger?
IMHO,
Before the blower is best.
If you wanna run it after the blower, run a micro switch to trigger the charger once the throttle reaches the off idle position. Otheriwse you close your TB, and the pump will blow your intercooler piping off.
Throttle body is after the blower. Mayturn out to be the wrong to have done it (I'm sure I've got lots wrong) but I'm running two blow off valves to make sure it doesn't blow off the intercooler piping (hopefully). May have got it wrong but that's how it's setup
Posted: Tue Feb 02, 2016 10:05 pm
you'll find that the blow off valves will make a horendus noise.
And with no restriction on the inlet, you're going to be seeing full boost pretty much all the time.
Even if you fit a WOT switch, you'll find in your tuning you'll maps will jump all the way to the maximum end of the load table.
Posted: Fri Jul 08, 2016 4:59 pm
by Godzilladat
Any updates on this beast?
