Page 18 of 34
Re: Nick 1200 sedan
Posted: Thu Sep 30, 2010 12:42 pm
by Blair
nick_m wrote:standard 1200 one and weld on the pedal instead of having the nasty floor hinging jobbie
Or use a B310 pedal set up. One in the shed if you need it.
Re: Nick 1200 sedan
Posted: Thu Sep 30, 2010 2:04 pm
by nick_m
Yeah, won't say no, dead keen actually. might even be bolt on?
When you coming up next? I'll catch up with you
Re: Nick 1200 sedan
Posted: Thu Sep 30, 2010 2:16 pm
by Blair
Nah it wont bolt straight up, but from what I have played around with it will work. Just need to get in the position you want and screw it onto the wheel well/fire wall, kinda were the STD B210/B310 one is mounted.
Im not coming up to CHCH for awhile now, as I am due to have another op and it will put me out of action for about 6-8 weeks. I will dig it out and give it to either Kitch or Simon and they can give it to you at Akaroa.
Re: Nick 1200 sedan
Posted: Thu Sep 30, 2010 4:54 pm
by z181200
Sweet shifter i need one of those too.
Re: Nick 1200 sedan
Posted: Fri Oct 01, 2010 12:43 am
by nick_m
it was pretty easy to make. Got a bit of tube from work 16mm od and I think 12 ID. Put a long m10 bolt up the guts of it and bent it in the vice with a big bit of bar on one end. The bolt was big enough to stop it collapsing to much but small enough that I could still tap it out from the other end. Then I used part of the of the original stick I cut off that has the bend in it and turned it round to 's' it back the other way with a bolt with the head cut off welded on top.
Feels way better although now 4th is pretty much straight up and down which is a little wierd at first but its now in a WAY more comfortable position from the race seat than it was also puts it up a nice distance from steering wheel too
I can bash one up for you if needed
Re: Nick 1200 sedan
Posted: Fri Oct 01, 2010 12:47 am
by nick_m
Blair wrote:Nah it wont bolt straight up, but from what I have played around with it will work. Just need to get in the position you want and screw it onto the wheel well/fire wall, kinda were the STD B210/B310 one is mounted.
OK cool thanks Blair, text me if you want sorting out for it. Hope the Recovery goes well!
Re: Nick 1200 sedan
Posted: Sun May 22, 2011 6:22 pm
by nick_m
OH HAI
Re: Nick 1200 sedan
Posted: Sun May 22, 2011 6:37 pm
by skdmrx
Youve got a thing for reconverting rear ends don't you.First you sucker me into doing it now your changing yours.Looks good dude
Re: Nick 1200 sedan
Posted: Sun May 22, 2011 6:45 pm
by crustywhip
Whats lurking back there
Re: Nick 1200 sedan
Posted: Sun May 22, 2011 7:03 pm
Now you MUST go irs and fit huuuuge tubs too nick!
