James Z31 Engine Blueprinting
Re: James 85 Z31 300zx -Detonated now running like a bag of
[quote="Bartman"]I read somewhere that BeeR limiters aren't too good for your turbocharger.
Spoken like an expert Bart, but a Beer limiter and Bart aren't two things I'd associate together, guess that's why you put the caution on the end. "(Don't quote me, I might have that wrong)"
85_Z31
Post by 85_Z31 »
Bilge pump + KEG = high pressure ( turbocharger like ) beer delivery ?
there ya go , thats a situation for a BEER limiter :D
85_Z31
Post by 85_Z31 »
Righto
Did some more tuning , more aimed at the low speed low load fuel economy side of things.
Getting there incrementially, daily driving it I notice i was seeing boost like mixture's when nana driving around.
I mean i know its going to use tons of gas but there is no reason to give it away !!!!
and in other news
My Koni Adjustable rear shocks arrived today ! yusssssss so there going under the tree
"To James from Santa"
But my passenger window will go down but it wont go back up (electric) & I am about to investigate why the heater is always stuck on heat ( 27 degree's today - fully not nice blowing hot air when its set to cold )
85_Z31
Post by 85_Z31 »
Project Car's
sigh
Injector No6 appears to be leaking and the surronding area is wet and stained a bit yellow.
it could be a fuel rail or the injector itself, i did already use all new high pressure hose and clamps to replace the old ones.
Anybody know of a Nissan R32 GTR yellow top 440cc injector?
85_Z31
Re: James 85 Z31 300zx - Leaky Injector Syndrome.
Post by 85_Z31 »
Right
Ordered 6x new injector Lower O rings in the hope that one of those went leaky and the actual injector itself is ok
( otherwise I'm stuffed for the next cruise )
So I'm in the process of cleaning & reassembly at the moment on that front
and a few days ago I did an engine bay tidy up by
Removed Idle Control
Removed Water Lines from throttle body
Removed Water Lines from Intake Plenum
Removed Complicated & messy as PCV breather system
Installed Filters on both valve covers
Tidy'd up some wiring
Tidy'd up some vacum lines
End result
Looks way cleaner, I can actually get to injector plugs and spark plugs now. Wiring is very easy to install and remove now and it Idles just as nicely and stabe as it did with the horror story of plumbing attahced
Picy's
Before
After
85_Z31
Re: James 85 Z31 300zx - Engine Bay Tidy Up
Post by 85_Z31 »
Bad News
no6 Injector still leaked fuel after I replaced the O rings
Good News
$100 on trademe got me a set of 3 injectors which gives me 1x replacement & 2x spares
Crisis = Averted now i just need to get them ASAP to enjoy summer crusing
85_Z31
Post by 85_Z31 »
Got sick of not having some form of music while driving
Before akaroa i busted out some cassette tapes for the old am/fm cassette tape deck ( original ) in the car
It ate the tapes, would not let me eject the tape and continued to make horrible screeching sounds until i jammed a big screwdriver into the slot and broke a whole heap of stuff to make it shut up.
Roll forward 3 months I made a panel with 2 switched aux power supplies fused from the battery, and then cut a slot in it for a standard DIN head unit.
The hold head unit was about 1.5 din tall and a bit wider so it left tons of room.
and usually the passenger side of the car is a mess.
the ecu cover is usually removed to allow access to the usb port for tuning. and i had these 2 thermocouple probe connectors randomly dangling around the foot well. So i did some sneaky hiding of USB and thermocouple cables and stuck them in the ash tray for easy access when required. and when not in use it looks nice and clean
torqued
aka: Adam
Re: James 85 Z31 300zx - I now have music !!
Post by torqued »
Hes good wifh sounds ya'know
Doof Doof
85_Z31
Post by 85_Z31 »
torqued wrote:Hes good wifh sounds ya'know
Doof Doof
Hey Adam I should have txt u back about catching up I was in the Mt Cook Area/Southern lakes area at the time. this weekend might be good ?
torqued
aka: Adam
Post by torqued »
Sweet. leemme know what when how where etc
