Re: Buddy's Datsun 260c (330 Series) Brougham.
Posted: Tue Aug 23, 2011 11:05 pm
Yeah I have an optical dizzy. I think it was off an L20ET out a paul newman edition skyline that had rusted away, it had been sitting in a paddock for a while. I opened it up and it looked like the circuitry was covered in shellac but seemed like it was all good. It wasn't working on the bench wired up to the MS (Giving it a 12v supply as per the instructions I found online).
So I gutted the dizzy and retrofitted a sensor from a RB30 from a R31 skyline. (The wheel lines up perfectly as the original and has the same wheel config etc). But that also wasn't working so I checked my VR + Pullup settings with the manual and it seems I have it all right so Im not sure whats wrong so I feel checking it with a stimulator could reveal whatever issues I may have.
I have had it connected up to tunerstudio and had coolant sensors and stuff showing up properly, just nothing in the RPM or cam and crank logs.
I wish I was as lucky as you to get it running easy peasy
I've messed something up...
Surge tank is definitely a good idea. I intend to go all out on this thing but I'm usually quite poor so I do what I can with the money I have when I have it. Hence why I bought a megasquirt, its the cheapest ecu that can do the most and be reusable in the future (hopefully).
One of the next upgrades (should cash flow permit it) Is A new fuel tank,surge tank and fuel lines. After that I want a big ass radiator and electronic water pump.
My way of thinking is that I should upgrade things that will remain in the car (or could be transferred to a new car if I had a crash, or god forbid I don't like the datto anymore.) or if I did an engine swap.
