Re: Dattochriswagons KH330
Last edited by Dattochriswagon on Thu Oct 17, 2013 3:18 pm, edited 1 time in total.
- Brnwgn
- aka: Hayden
glad to hear
- Josh
- aka: SeEn-ThE_lIgHt
1972 B110 Deluxe~ Daily
1965 P410~ Wifey daily
Last edited by Dattochriswagon on Thu Oct 17, 2013 3:20 pm, edited 1 time in total.
- mint16
- aka: Brendan
do the throts, and let someone else worry about wiring and ecu
christ, now i have to get those rods for you!
It will be expensive Chris, I contemplated this but for the same money (around $3k, not including carbs which will be $2k by themselves) I figured that is close to a RB25DET with twice the power.
Lets look at what is needed
LD28 crank = can sometimes get for $100 off trademe if your lucky or can be arsed removing yourself from a dud motor
pistons = I got six brand new OEM KA24DE pistons for $150 landed and that was a FARKIN mean deal
block bore to 89mm = you better have a good machinist cause this is on the edge, if he fucks it up your motor wont last jack
full gasket set = shit one around $80 nissan = over $200
oil pump = aftermarket standard shit one = $70, Nissan one = over $150 and a L28 turbo one is the one to get
decent cam = over $300
no point doing a stroker without a decent head job = $500 - infinity !
l28 motor = $200 if your real lucky
with that not including the machining required the price is $1400 just on some of the parts required.
L series are really adversly affected by balance, so a real real good balance of rotating assembly needs to be done
However if you get stuck I may part with my LD28 crank and L28 block.
L series ignitions are shit, even the electronic ones, I have spoken to many people running strokers in NZ and they ALL use MSD 6A or 6AL systems.
Flauski wrote:It will be expensive Chris, I contemplated this but for the same money (around $3k, not including carbs which will be $2k by themselves) I figured that is close to a RB25DET with twice the power.
You make a valid argument there Tony.
There is a shop here in town which has a very sensitive balancing machine. But he isn't especially cheap................
but neither is rebuilding a stuffed motor now is it bart?
- DylPhil7
- aka: DylPhil
L31! as its not all about power ae!! A nice L in the right car is nearly unbeatable
