Page 3 of 29
Re: D1RTY6 's 1978 C331 Gloria SGL-E
Posted: Tue Mar 20, 2012 2:01 pm
You can get a factory service manual for a 280ZX here:
http://www.xenons130.com/reference.html
The torque specs will be the same, it depends on which head bolts you've got though, some are just plain on the top and then some have an extra ring which are the "turbo" head bolts, there should be a picture of them in the FSM.
Posted: Wed Mar 21, 2012 5:27 pm
by D1RTY6
DJZ wrote:You can get a factory service manual for a 280ZX here:
cheers mate,
So thought id start putting this beast back together today..... until i decided it would be a good idea to check the water pump out while everything was so open
i found this ....Yes that is fins missing!!!
which in time turned to this
Needless to say it is alot better that I found it now rather than when the cars over heating again ....my question is how do I get the pieces that are missing out of the block?
Nathan
Posted: Wed Mar 21, 2012 6:33 pm
They've probably rusted away into nothing by now, just make sure you give the block and radiator a good flush/back flush.
Posted: Wed Mar 21, 2012 10:00 pm
by brocky41
There should be one of those at Bnt too, ring Rodney again aye haha.
Posted: Thu Mar 22, 2012 3:47 pm
by D1RTY6
brocky41 wrote:There should be one of those at Bnt too, ring Rodney again aye haha.
Gave them a ring they don't think they have one. They want to know if the L28 has the same water pump? anyone know?
Posted: Thu Mar 22, 2012 4:01 pm
All the 6's except the LD28 should have the same pump, just make sure the overall height is the same.
Posted: Fri Mar 23, 2012 10:34 am
by brocky41
DJZ wrote:All the 6's except the LD28 should have the same pump, just make sure the overall height is the same.
What he said.
Pretty sure ones iv done were the same aye. That corossion usually happens when the engine has been sitting dry for a long time. Had a few come into work like that that were from conversions.
Posted: Sat Mar 24, 2012 10:39 am
only thing you might want to check on the new pump is the diameter of the pulley spigot. I had a pump once that had the wrong size (too big) and it wouldn't fit. Better to check that at the begining, rather than after you've put it all back together.
Posted: Sun Mar 25, 2012 5:57 pm
by D1RTY6
Shes alive!!! Finally got the old girl all back together over the weekend, fired her up and no bangs!!
so looks like everything is how it should be.
Until........ I could here water leaking.
had a quick look around and found this thing was leaking water (was leaking with hoses on just to clarify that one ha)
so there goes my plan to drive it this weekend.... anyway does anyone know where i can get one from? are they quite common/Universal? or am i going to have to get a second hand one of someone?
Nathan
