Put it on the list, wanna do it one lunch next week?
I just borrowed a trick snap on timing light from work an did the timing on the l26 it was way out and it has a digital tachometer so got the idle revs down to perfect 650 even with new thermostat these tend to be shit cold. Youll also want to readjust the tappets before doing the timing.
Huge thanks to James for doing the brake pads for me while I was busy getting the CA ready for test fire. Found a few unsettling things while James was doing brake pads, both front wheel bearings were quite loose
split tie rod end boots (didn't get pulled up on this but will fix at a later date) one of the wheel studs on passengers side front hub is shorter than the others
That's all that I can remember James may be able to comment if there is anything else.
Vaughan lunchtime wouldn't really suit me as I only get a 30min break and wouldn't have time to get your place fix everything up then make it back to work. I do however finish at 2pm on fridays so let me know if that works for you.
Tie rod ends L & R need replaced
Ball joints on the drag link ? ( the big long one that goes from side to side ) L & R need replaced
Rear Brakes need bled heaps
How did it drive today Greg ?
Pretty good James apart from stalling when cold all the time
Alrighty! A few weeks back I took the old girl to see the L series master Vaughan(Classicdat), we changed spark plugs fitted new points, set dwell and adjusted timing. She runs so much sweeter now. Does not run terribly from cold any more although still needs a decent warm up in the mornings otherwise she'll stall at intersections etc. Also for the Hanmer cruise not so long ago I decided to fit the B-Bombs from the 180B for the fun of it. Can definitely go wider all round quite easily! Wheels are in need of a balance though as I was getting some nasty vibrations through the steering wheel at high speeds which in turn made my right front wheel bearing quite noisey. Replaced wheel bearing on Sunday and re-fitted factory wheels. Did get some shots of the B-Bombs on though look pretty good on there, and before anyone says anything. YES I KNOW IT NEEDS MORE SLAM!! So may look into finding some rims for her at some stage and touch of low. But 180 is the priority right now.
After nearly a year of possession I've finally got motivated to get some decent sounds in this old girl. So on my lunch break I removed the stereo surround to see if the face plate that holds the am radio was removable. It's not
it's actually part of the mount itself. So to put in an aftermarket stereo I'll have to cut out the plastic for it to fit thus making it non original.... thoughts? My other idea was just to have an amp under the seat running some speakers and have all music controlled by my ipod but amps are not cheap and a bit more mucking around with wiring. Keep in mind I pretty much want something in there this weekend ready for the OS Hanmer trip the following weekend.
Amp and an AirPort base station to wirelessly send music to your car from 30 meters awayDatto_610 wrote:After nearly a year of possession I've finally got motivated to get some decent sounds in this old girl. So on my lunch break I removed the stereo surround to see if the face plate that holds the am radio was removable. It's notit's actually part of the mount itself. So to put in an aftermarket stereo I'll have to cut out the plastic for it to fit thus making it non original.... thoughts? My other idea was just to have an amp under the seat running some speakers and have all music controlled by my ipod but amps are not cheap and a bit more mucking around with wiring. Keep in mind I pretty much want something in there this weekend ready for the OS Hanmer trip the following weekend.
I wouldn't even bother with that,
Just subscribe to Itunes Match
