Page 3 of 8
Re: CA 510
Posted: Thu Feb 06, 2014 9:33 am
Gotta keep the bastards alive! (and sideways!)
Re: CA 510
Posted: Thu Feb 06, 2014 10:51 am
by gingofthesouth
Bartman wrote:Gotta keep the bastards alive! (and sideways!)
Like you say Bart, a rusty Datsun on the road is better than a pristine one in the garage!
Just for you Bart:
Re: CA 510
Posted: Thu Feb 06, 2014 12:25 pm
by gingofthesouth
Somebody has some explaining to do. I went to take the subframe apart that we just took out of this 510.
The U joint bolts that join the half shafts to the diff were barely more than finger tight.
Then once they were off, the center bolt on each side that goes through the diff flange into the diff were not even done up. They were loose!
What a joke!
Re: CA 510
Posted: Thu Feb 06, 2014 12:28 pm
:o :o :o :o :o :o Just as well you guys were replacing it!
Re: CA 510
Posted: Thu Feb 06, 2014 10:28 pm
by DylPhil7
Just as well I didn't drive it from Auckland haha
Re: CA 510
Posted: Thu Feb 06, 2014 10:55 pm
by gingofthesouth
DylPhil7 wrote:Just as well I didn't drive it from Auckland haha
There was a nut missing off one of the half shaft outer flange bolts...
Re: CA 510
Posted: Fri Feb 07, 2014 1:35 pm
by broke
Possible explanation for the noises you were hearing. My old one has a Subaru R160VLSD and some hero had made it fit by welding the Datsun UJ yoke to the Subaru diff flanges (which are circlipped in), the problem being that it wasn't an ideal setup for a very low car, and one side used to pop out all the time, leaving me with a 1-wheel drive car.
My mate's old 910 SSS-X turbo had a similar issue, it had a factory R180 LSD with circlipped axles and when we put it on a hoist it was clear why they were popping out - some monkey had actually sliced right through the circlip groove, leaving them just loosely sitting in the diff!
Re: CA 510
Posted: Fri Feb 07, 2014 2:04 pm
by gingofthesouth
broke wrote:Possible explanation for the noises you were hearing. My old one has a Subaru R160VLSD and some hero had made it fit by welding the Datsun UJ yoke to the Subaru diff flanges (which are circlipped in), the problem being that it wasn't an ideal setup for a very low car, and one side used to pop out all the time, leaving me with a 1-wheel drive car.
I took the drums apart, as the right side was jamming. It turned out the diff was fine. It was the pads off the drum brakes that were off the shoes, causing it all to jam up.
Just an abortion of a rear end.
Re: CA 510
Posted: Wed Feb 12, 2014 7:59 pm
by DylPhil7
Looking more like a Datsun haha...
Re: CA 510
Posted: Wed Feb 12, 2014 9:16 pm
by gingofthesouth
Good work dildo! Come finish mounting that bitch tomorrow and bring the light buckets and lights.
