O shit this is what happins when you get to clever
Re: O shit this is what happins when you get to clever
which head is the "one to get"?
- gman
- aka: gman
Hy Bart the head that I had on there was a p90 with 13 to 1 comp.but this time I am going to do a n42 with bigger valves again lesser cam and more comp.Bartman wrote:which head is the "one to get"?
I'll see what heads my mate has. he's got a pair of old L26's that I suspect he'll sell.
- gman
- aka: gman
Spring is here time to fix this thing pistons and rods arrived the other day so I enlarged gudgeon pin to 22mm and will bore the block over the weekend .
Nasty Situation there, Best of luck getting it all sorted.
Did the block and crank survive or is the bore quite damaged ?
- gman
- aka: gman
crank block and rods came out alright so I can rebuild that as a NA motor But I want to do a treble blow through turbo motor that I can run in the classics and GTs .85_Z31 wrote:Nasty Situation there, Best of luck getting it all sorted.
