D1RTY6's C331 Gloria
D1RTY6
aka: Nathan
Post by D1RTY6 »
DJZ wrote:Those wheels are sweet, how wide do you think you can go front and rear?
Basically what ever i can fit under the guards at this stage im thinking 9s in the rear and 8s in the front
brocky41 wrote:i think they come in 8's and 9's from memory - pretty awesome wheels.
They actually range from 15x4 to 15x18.25!!! http://weldracing.com/15-in-s71.html" onclick="window.open(this.href);return false;
Although i think 18.25 wide is more of a drag application! ha
D1RTY6
aka: Nathan
Post by D1RTY6 »
Started Changing over my Fuel pump from the EFI one to Carbed ! (probably left that a bit long!)
But as i was removing it i bend/Broke one of the inlet pipes ...anyone know where i could purchase one?
Nathan
torqued
aka: Adam
Post by torqued »
Give this muppet a call
021 023 10952
D1RTY6
aka: Nathan
Post by D1RTY6 »
torqued wrote:Give this muppet a call
021 023 10952
Ha i thought John or Brock might have something.
Ill give one of them a call tonight.
torqued
aka: Adam
Post by torqued »
John works at Hydrolink which if they dont have something at home he will at work
brocky41
aka: Brocky
Post by brocky41 »
And if he don't we night at work lol
D1RTY6
aka: Nathan
Post by D1RTY6 »
brocky41 wrote:And if he don't we night at work lol
Cheers Guys, Have got it sorted now! :highfive:
D1RTY6
aka: Nathan
Post by D1RTY6 »
update .....Not sorted :(
the brass hose downsizer i have used is leaking at the joins
Will thread tap disintegrate if i use it to seal up the joint?
DJZ
Post by DJZ »
I think the proper fuel proof thread tape is yellow but I've used the normal white stuff and haven't had any problems. It's definitely going to leak if you don't have some sort of sealing stuff on there. We use Loctite liquid thread sealant at work sometimes too.
Nissan 280ZX
Project thread
Other Nissan 280ZX
Project thread
broke
aka: John
Post by broke »
Hose downsizer? Did you put a joiner fitting in the hose, or did you find something to thread into the fuel pump? If you put a joiner in the hose and you want to put thread tape around it to build it up, then that won't work.
If you put a fitting into the pump and it's leaking from the threads, then you probably put a NPTF fitting into a BSPT port.... Or vice versa. They are similar, but have different TPI and taper angles. Thread tape may work, but you'd be better off using the right fitting.
