Well the Ute made it to nationals in Cromwell. It was a massive mission to get it there.
Bert ended up travelling down to chch with Ange, Olivia and I. So he and I ended up pulling the gearbox back out and removing the sandwich plate. Turns out I needed the half plate as there still wasn’t enough movement to engage the clutch. This meant removing the exhaust so we could tilt the engine. What a frigen rigmarole that was. Also, while I was at work in the AM, Bert hooked up the dash which was a massive job on its own.
When in chch I delivered it to Damon @ RockyAuto. He then had to prime fuel pump, replace starter motor, build engine oil, tune Dhla40, Weld door frame, replace brake line, fit bump steer spaces, fix horn, wheel alignment, WOF.
Had to increase both idle and main jets on the dhla. Even now, it still kinda runs lean when it gets the jandel, but that can be sorted out at another time session.
Didn’t get it running well enough until 1pm Friday and still had the drive down to Cromwell to complete.
Loaded up the transport trailer and we were off to Nats!
After Nats, I towed it back to Nelson. Dropped off the transport trailer and drove the Ute back to Blenheim. Ended up loosing the tail light and rego plate somewhere between Murchison and Nelson.
Thing is an absolute beast and pretty fun in the wet
Next on the list is to curve dizzy and put some sound deadener to quiet things down a bit more
