Yeah, needing a twin choke cable for SU's.Thejack3S wrote:SU Caburator ?
82' 910 Bluebird
- skutaman
- aka: Bert Newcombe
Re: 82' 910 Bluebird
- skutaman
Yeah man, thats what my lil Annie is going to be breathing through soon..Thejack3S wrote:Like This?
- skutaman
Here's a sneaky lil pic of my mates L18+ET setup in his P610 sedan...
He recently had it Dyno tuned to the tune of 150Kw/230hp atw on 10psi.
He's de-tuned it to 190ph atw for daily/practical use lol
- skutaman
So I've got my head off, looks like theres been a bit of blowby from #3 to #2 by the looks of the head gasket
It has definitly had something go thru the #1 cylinder, but it must have occured on the previous motor because the piston/bore is unmarked... Question: what is the standard cc of a dished piston L20b at TDC? (just the bore, not including the gasket or the cylinder head)
I have cc'd the chambers in the head to be 39.6(ish. not the most ideal seringe...)
I know Grandad got the head from down the coast somewhere, despite all i have read about the 210 heads supposably being open chamber heads, this one is closed...
- pl510
- aka: Shannon
l20b piston dish volume 11.36cc plus volume of cylinder above piston at tdc?
- skutaman
Sweet cheers
- skutaman
Looks like Annie will be running at a nice 9.5/1 compression ratio.
Should be ok to start with...
I've got one of the carb bell housings polished, just chugging along on #2.
Also my twin choke cable turned up to day, cheers fj20_180b!
Shes coming along slowly... 5weeks till the Dr. gives me my licence back!
The butterflys in my stomach just keep getting bigger and bigger!!
Oh man, I bet you're looking forward to that!
Best of luck to you mate.
- skutaman
You have no idea man...Bartman wrote:Oh man, I bet you're looking forward to that!
It's been 19 months on a pushbike, and I had 7.5 years on a scooter before I was allowed to get my restricted.
Then three weeks later I had a seizure and the Dr. took it off me...
But!! All is well now, and I'm getting amped! (As you do....)
Progress:
Polished one carb piston chamber, halfway through the other... I've got the cam back in its rightful place, and heads ready to go on!
...As I said, getting excited! lol
