Page 23 of 80
Re: James 85 Z31 300zx - Ramblings of Bump Steer spacers
Posted: Thu Jan 13, 2011 6:39 pm
by dirtyleppa
what are the ball joints and tie rod ends like? if those are fucked, could cause some form of shudder
Posted: Thu Jan 13, 2011 6:54 pm
by 85_Z31
All brand new and as tight as a .........( use imagination )
Posted: Thu Jan 13, 2011 6:56 pm
by dirtyleppa
as a square pig in a round hole?
Posted: Thu Jan 13, 2011 9:28 pm
by 160jsss
Posted: Thu Jan 13, 2011 10:12 pm
by 85_Z31
Day off work today looking after the unwell missus
got really bored
did this
Pretty Rough but if anybody wants a set of plans to build these from scratch I am nearly done, it will will include various revisions over the CUSCO's including a stronger replaceable bearing and a PCD to suit whatever your application
If you had a lathe and some patience these would not be exceeding difficult to make , but very time consuming
Posted: Fri Jan 14, 2011 8:25 am
by 160jsss
Man i wish i could use a computer for more than trademe and datsun sites thats so cool .
Are you going to make up a set yourself
Posted: Fri Jan 14, 2011 11:49 am
by datsunboy
those look pretty sweet mate!
any chance I could get a copy of the DWG after youve got them done?
could mod it a bit to fit my wifes 140J
Posted: Fri Jan 14, 2011 12:19 pm
by 85_Z31
datsunboy wrote:those look pretty sweet mate!
Yeah man
Just give me tonight to finish them off for my own purposes and i will email you a .DWG file
Basically they are an exact copy of a CUSCO s13 plate that uses a more standardized industrial bearing all the part No's ect are in the drawings
if you pm me your gmail or whatever you use we can go from there ! ( this is the reason i draw up this stuff its great to know that somebody else can benefit )
Posted: Fri Jan 14, 2011 12:24 pm
by 85_Z31
160jsss wrote:Man i wish i could use a computer for more than trademe and datsun sites thats so cool .
I purshased a set a while back and the bearings were fucked & the bearing retainer was all grooved out and rusty so i was unable to replace the bearings. Also the stud pattern didn't line up with my 300zx
I had to do an accurate drawing so i was able to confirm that i can have them bored out to accept larger bearings of a more standard nature ( IE sealed PTFE lined ect from Wilson Bro's ) and then because of the stud placement issue i had to draw up the uppers so that the engineer can weld up and re spine the hole where it needs to be.
This all resulted in me going fuck it i might as well draw these up properly so somebody can build them from scratch.
I also made some revisions including making the upper plate 10mm instead of 6 & adding more bolts on the plate that holds the bearing in ect.
Posted: Fri Jan 14, 2011 1:34 pm
by Mikewazowski
Nice work James. This sort of stuff could prove useful to quite a few people
