Getting it welded is not the problem
the problem lies in that the casting between a 1984 manifold and a 1985 manifold is diffierent
which means that with 10mm exhaust studs ( factory was 8mm ) clearance for the nut is already tight enough i had to grind the shit out of a socket ( no access with an open end spanner )
the crack is right in the groove where the socket has to slide in to.
which means that any welding ( strong enough to do anything ) in that area will mean i have a manifold that i can't bolt to my cylinder head.
I guess i could slap it on the side and run it until my WOF runs out ( 1st may ) and then finish these
The shorty headers are the easy bit, getting from each header to the turbo & where to put the turbo and wastegate is the difficult bit which is exatly why i havn't got that far.
