Depends how rich I am in 6 months, at a minimum it'll be a fancy oil pump and forgies, if I've got the cash I'll get some fancy rods too but that depends on what I do with the head as well, I'd like to get some cams and Jun cam gears, it starts to add up pretty quickly. If I can find another crank and fix the 26 I should be able to sell that complete (minus the turbo) and that should pay for most of the RB30 build and buying another 26 head.Bartman wrote:Are you going to freshen this engine up, or is it just going to be a slapper? (I vote forgies, and a nitto oil pump) If you need oil restrictors, I should be able to arrange some for you. (Unless you know someone else with a lathe, there isn't much to them)
The block needs to be drilled and tapped for the 26 head studs as they are 12mm from memory when all the other RBs are 11mm (corrected) but that's really the only mod to that, other than moving the tensioner.
