Oh I see, thanks for clearing that up for me James. Sounds like a good idea I'll look into it.
This is probably what I'll end up getting http://www.datsport.com/adustable-rearxmember-kit.html" onclick="window.open(this.href);return false; unless anyone has there own adjustable kit or is keen to develp one so its cheaper than buying it from oz??
85_Z31
Post by 85_Z31 »
That kit is quite expensive, However it is a nice complete ready to roll kit.
If you wanted to Greg, you could bring a cross member out, we could draw it all up in Auto Cad and Nick M can probably get all the pieces laser cut ?
torqued
aka: Adam
Post by torqued »
I'll like to get in on that :D
Sounds like a plan!
Intercooler pipes are 90% done!!! Gave a template to autobend which was a couple of bent up curtain rails(courtesy of Datsunboy) They costed a fair bit but needed to be done. They were made a lot longer than needed so had trim quite a bit off had to start cutting small bits off at a time then testing it when I got home then back to work to cut more off... But finally finished and Im stoked with the result. All I need to do now is get some fittings welded on to the pipe on intake side for the blow off valve and I cant remember what other one was for Dan will know :D Dont have much room for the turbo intake pipe but now that the cooler pipes are done I can at least work something out. Pipes will be getting anodised satin black once they are fully finished for that extra stealth look :dance:
I may even buy some of that flexi radiator hose stuff in the weekend so everything will be plumbed up for start up! :burnout:
torqued
aka: Adam
Post by torqued »
Looking really good dude, Bet youl have your hand on it all night thinking about its start up :D
Whats the deal witht that radiator cap housing? Is it just a plump in hose thing? Can i get some pics of it?
datsunboy
aka: Dan
Post by datsunboy »
Awesome work mate.
You'll need a fitting for your bov on the throttle body side of the intercooler piping. And then another footing for the plumb back pipe from the bov in the intake pipe between the maf and the turbo.
It's just a remote reservoir Adam think there is a pic a few pages back before i anodised it. Dan wasn't there something else that needed to be plumbed into the pipe on the inlet side like cold start or something like that?
It's a remote fill isn't it Greg?
