I think here you are talking about the boost switch. You can find which wires go to it on the wiring diagram. As for the location of the plug from memory it came out of the cable the goes towards my battery. If you look at the photos of my engine bay you should be able to see it secured to the rear of my engine bay (near the metal ID tag with engine number etc). I just put a vacuum hose that seemed appropriate onto it.jasace wrote: what & where do u wire the lil round black plastie thing that has a lil nipple off it for a hose?
maybe a air line?
Boost sensor? Do you mean the switch that I've detailed above?jasace wrote: What & where do u wire the boost sesor?
Any help wood b good as the wirein diagram & colours of wires dnt all match the loom i hav?
Yeah not all the colours matched on my loom either, but you can check which ones are which by testing the continuity from the wires to the pins on the ECU plug (be aware that some of the wires are connected in the loom though so they will have continuity to multiple pins).
