Kitch's 120Y
Re: Kitch's 120Y - "A12 and Auto awesomeness"
Just wondering if the whole pedal box has to come out? Not a conversion I have done but it would surprise me if Mr Datsun had two totally different pedal boxes, I thought you would have been able to just swap pedals over, can this not be done in place? That makes this a bigger job. Keep up the good work.
brocky41
aka: Brocky
Post by brocky41 »
Problem is no one has the clutch pedal and brake pedal by itself, they are usually sold with the pedal box, they hav a longer bolt etc to fit 3 pedals.
So the pedals aren't interchangeable? The metal folded into the box shape is different? amazing, One thing I have appreciated about Datsuns is the interchangeability of parts and them not seeing the need to reinvent the wheel for each model variant.
torqued
aka: Adam
Post by torqued »
me and Greg are seeing a lot of differences between the 510 and 610.
He has noted the rear subframe is different and i have just seen the heaters and heater boxes completely different
Kitch
Post by Kitch »
Basic pedal box the same, but the manual one has additional folded metal to LH side thats
added on to hold the clutch pedal setup.
when i jimmy out the old pedal box will take a comparitive photo FYI
Thanx. Sounds like it will be a bit of mission.
it was a piece of piss on the 910.
Blair
Post by Blair »
Shit, I didnt know it had tried to fall on you. If you need a hand, text me. Ive still got my fingers crossed about that drive shaft.
Kitch
Post by Kitch »
Blair that drive shaft came up OK, I just used one of those paint stripping woven wheel things, then gave it a rub with some 800 grit wet n dry
I got the new pedal box in, just needed to cut a couple of studs of, and drill new holes for the 4 bolts from the brake booster mount block.
Should get box in tonight an back down on the ground - I better cause Karen gettng shitty with her car parked outside in the rain
Kitch
Re: Kitch's 120Y
Post by Kitch »
Finally got gearbox in last night, and connected up drive shaft.
few we jobs left, like installing starter motor, modifing gearbx mounts,
minor wiring changes etc, should have on the ground and ready for road test in a couple of days
Got the pedal box all in - was straight forward exercise in the end (thanks heaps Scotty BRDFLU)
