Page 4 of 8
Re: Brock & Lisas 1200 Project
Posted: Fri Nov 25, 2011 3:14 pm
by brocky41
Bro rotors in datsuns are all g specally wif my flat peak hat on. I'm thinking about a monsta bridgey turb with race cut cam make it pulse hard. ill post up a pic tonight of the bodykit I found for it too
Posted: Fri Nov 25, 2011 9:20 pm
by broke
You absolutely MUST post your inspiration pic of that blue 1200 here.
Posted: Fri Nov 25, 2011 10:20 pm
by brocky41
Posted: Sat Nov 26, 2011 11:24 am
by Kitch
I think when you do a cyborg conversion you are meant to swap the turbo mitzi running gear not the headlights....
Man that is so criminal - and someone has worked hard to get it like that...
Posted: Sat Nov 26, 2011 11:32 am
by darrenwilson
Posted: Sat Nov 26, 2011 2:26 pm
by brocky41
Oh yea so do we. Some people have no idea . This probably would have been ok before they started on it haha.
Posted: Sat Nov 26, 2011 8:41 pm
by Josh
WOAH!
Posted: Tue Jan 03, 2012 10:47 pm
by brocky41
Little bit of an update....
Engine out again - Thanks Earthquake - cross member in with s13 lower arms and 4 stud hubs. Got the coil overs in just had to lick up the 3 stud holes with the drill (larger stud) and they are in too.
The s13 arms are way to long - would be around 4 degrees neg camber and could only run high positive offset wheels ie +38 like the skyline wheels i used for a mock up, so next thing is to chop up, rose joint, make them fully adjustable and work out what to do for castor arms.
Tyre rubbing dude to no disks on hubs
Posted: Wed Jan 04, 2012 9:01 am
by nick_m
hey brock apparently s12 bottom arms bolt up and are shorter (same ball joint taper) might mean 910 bottom arms bolt up too. Might save you chopping up the s13 arms. Are I believe its r30 castor rods you use with the s13 arms
Posted: Wed Jan 04, 2012 3:54 pm
by brocky41
Sweet thanks nick, yea its finding something that has the same taper but you got me thinking now.....
