So I had a massive night in the shed and for some one of my skill, done and learnt a lot.
What would take you pros a couple of minutes took me a couple of hours but it was fun
Here is what I have done. Your ideas, solutions overly appreciated.
Got current struts out, Springs off and had a look over. These struts have been cut all over the place to allow for 17inch wheels and also the strut tube thingy has been shortened.
Got Brake calipers off and stripped them down and managed to clean most of the rust, grime and old brake oil out.
Noticed that brake lines are in different locations from drum to disc. Do I just bend the lines to fit or do I need to sort some coupe ones?
Looking at getting new strut tubes shortened again but hopefully get a better job done than black ones.
What's the legal dealio here?
When I fit the 17's on too, the wheels rub on the bottom of the spring tower thingy. Is it okay to cut a chunk out here like the black ones?
Time to ditch 17's for 15's?
I cant get the centre cap piece out of caliper piston A. Any ideas how I to it? Is it a matter of pliers and pull?
I pulled all the pistons out, rubbers and ring clips etc and managed to do it properly even taping up Piston B as to not confuse with Piston A as they are supposedly deferent.
when I stripped one of the brakes down there was one of these clip things missing from one side. Any one got one of these lying around?
Can I take the 4 bolts off that hold the disc rotor to the wheel bearing, or are they hard to put back together? Will they need balancing etc after or is it easy as?
Plans are:
-bush kit for the hole front suspension. Best place to get these, Repco, Basis, BnT???
-Unsure about cutting strut yet ... opinions???
-Switch over rear brake cylinder with coupe one I got from repco.
-When rolling she's off to shed to get rust cut out!
-Some prepsol to soak clean pistons, rubbers etc.
Scrub and paint brake callipers.
