I took it for blast round the port hills on thursday, feels real sharp- steering feels alot lighter, minimal body roll. It sticks to the road so well thru the corners, way less twitchy in a straight line, luvn it.
The last bit of decent road it saw was last years Akaroa cruise, and it only had 2" blocks and a respray back then, so really looking fwd to Akaroa this year.
I did notice quite a bit of drive shaft and diff noise under engine braking down hill on thurs tho,
and the odd bit of pinging noise from the engine on some up hill pulls
Interesting numbers Kitch, With the A15 and 5spd when i still had the 165/70/13's I was getting 3500rpm @100kph on the gps (130 on the speedo) , even tho its at 3800ish @100kph now, that 300 odd rpm extra feels more like 1000. To make it worse the exhaust gets a weird reverb/resonance around those revs too.
Will def be looking into some diff options.
Also yeah the 3" blocks are not exactly legit, tho i have heard of them passing cert if two link style tramp rods are installed.
The rear leaves have already been re-set as far as they would go without wreaking the spring effect.
In the future I may look at doing this kind of mod: From that to this And Dan, there was only one brand of tyre that I could get my hands on in that size, it was a toss up between the 165/50 and the 155/55 http://www.yhi.co.nz/tyre/ACHILLES/ATR-K_ECONOMIST" onclick="window.open(this.href);return false;
I got them through Mag n Turbo.
