So the ute got stickered a while back in march for no warrant, the cop even let me put the sticker on myself.
he didnt fine me the $200 as i was actually on a mission to get the parts nessesary to fix warrant issues.
so its been in wals workshop for a wee bit now and all rust has been dealt with, he has also got rid of the old factory mounts and made/making new ones that fit the 5spd box with a factory look to avoid cert process.
after i get it back il put the tierod end in and take it for its warrant.
it will eventually end up with the A15 that was in the coupe, but before fitting it i plan to get someone who knows there stuff to check it over fully to see what needs doing, and factory paint spec it all.
lukes 1200 ute
Re: lukes 1200 ute
1972 1200 coupe KB110
Re: lukes 1200 ute
Sounds like a pretty good plan luke, does it need anything else done before wof?
Be fun wee machine with a15 and 5 speed
Re: lukes 1200 ute
from memory the old warrant sheet said....
something tie rod end to replace
rust cut out
headlights dip/beam switch to work
take off stupid seatbelt mount adapter that makes it lower
POSSIBLY take off towbar depending on inspector.
sooooo...... bart has/is sorting the headlights dip switch thing.
wal has sorted the rust and gbox mounts in the tunnel
(pics soon i hope?)
il do the rest when i get it back
rust cut out
(pics soon i hope?)
Re: lukes 1200 ute
the ute is home!
REALLY need to sort front disks out, for better braking, and because the brakes need an over haul as only the back ones work, effectively no brakes the whole way home despite a good bleed etc.
but super stoked its all back
- aka: Scott
Re: lukes 1200 ute
So ... umm ... seems legit
1956 Morris Minor - one day A12
1982 Sunny wagon - A15 dogleg 5 speed
1984 Toyota Corona Mark 2 - GX61
- aka: Scott
Re: lukes 1200 ute
Fruit Luke
- aka: Scott
Re: lukes 1200 ute
Go work on your coupe Fruit Luke
