Page 4 of 4
Datto1200 Got a Coupe
Posted: Sun Feb 19, 2017 7:26 pm
by Datto1200
Better give an update. I have pulled motor and box out. Just need to pull suspension and brake lines out then off to the blaster. Image
Re: Datto1200 Got a Coupe
Posted: Sun Aug 27, 2017 7:38 pm
by Datto1200
Datto1200 wrote:Started cleaning up all the hidden roughness today by cleaning all the rubber sound proofing off to find more dodgy shit.
As you can see by photo's. Check out the carpet hidden box around gear stick and yes you can see day light though it if I put a light behind it. Not to sure on coupes floor pan but looks very high compared to sedan's is this normal? Needs few bits of rust done so looking at new paint. Once panel and rust done looking at a rewire whole as there's a lot of wires going nowhere. Probably half the reason it has a miss up in rev range. Put a boost gauge in it as the one that came with car went to 15psi and found car was running 18-20 psi. Went well when it didn't miss. dropped back to 10 psi and still goes hard but just a bit more drivable for streets. Found a photo of a white coupe on net that looks mean so looking at making it look like that. Trying to get this all done in 6 months as well as rally car rebuild so it be a year.
Posted: Sun Aug 27, 2017 7:40 pm
by Datto1200
Clean 6 + layers of paint off the roof today. Nice to see the roof is rust free
