Page 4 of 17
Re: 69 510 Ground Up Rebuild
Posted: Sun Jan 17, 2010 9:12 pm
by acustx
hsepwr wrote:Looking good, Im glad there are a few more 1600s getting attention in the north island we are a rare breed up here compared to those from the deep south.
Its slowly coming together. Where are you based?
Posted: Sun Jan 17, 2010 9:22 pm
by hsepwr
Hastings. I met you once a few years back outside brendans house after a cruise we had down here
Posted: Sun Jan 17, 2010 9:30 pm
by acustx
Oh yea cool, im headding down in a couple of weeks for the weekend, would be sweet to catch up.
Posted: Sun Jan 17, 2010 11:06 pm
by mint16
yup as mentioned via pm, ill organise a garage day for you greg if you have the time available
Posted: Mon Jan 18, 2010 6:21 pm
by acustx
mint16 wrote:yup as mentioned via pm, ill organise a garage day for you greg if you have the time available
Yea that will be sweet. Sat is looking at being the best day for it, but let me know if its easier for a sunday mission.
Posted: Fri Feb 05, 2010 6:52 pm
by acustx
Posted: Fri Feb 05, 2010 6:53 pm
by acustx
Yea I suppose I should get off my ass and give a bit of an update.
After sorting out the water inlet and water lines for the turbo I fitted the engine (again) and mounted up the intercooler and worked out how I was going to run the piping.
then had to make sure that I could clear the radiator.
Filled in all the gaps and wahla!
Now that I had both sides made up it was time to work on the fuel tank.
I purchased an R31 skyline fuel tank complete with cradle (which I found to be useless and ended up buying an R33 fuel pump cradle from the wreckers). I then cut the approprite bits out of the R31 tank and cut a corrisponding hole in my 1600 tank.
Then welded on new fuel line brackets bent up new lines and mounted on tank.
I then got sick of crawling under my car all the time and decided ot make myself a Rotissire.
Posted: Fri Feb 05, 2010 7:20 pm
by acustx
I did some reasearch on the internet and formulated a bit of a plan.
Used my skills as a quantity surveyor to work out how much steel I would need and ordered it.
I received the steel and got to work cutting it to length.
Tacked it all together
Clamped everything square and straight before welding.
Oh yea, I capped the ends of it all too.
All welded together.
Pivot boss and slide all welded.
Then I cleaned it all up and painted it.
Posted: Fri Feb 05, 2010 8:09 pm
by Dattodevil
some nice work there, I especially love the rotisserie, you should sell those
Posted: Fri Feb 05, 2010 9:45 pm
by 510BRE
mean rotiserie looks a hell off a lot tidyer than mine maybe i should spend more time on my rotiserie aye hahahah
.............well done man car is lookin good
