Page 33 of 125
Posted: Wed Sep 12, 2012 5:16 pm
by Godzilladat
Greg i used a 15/16th master on my 610 coupe, I just cut off the very end of the nipples and drilled 2 holes in the strut tower for bleed line access.
Posted: Wed Sep 12, 2012 8:32 pm
Bartman wrote:How much too big is the spigot Greg?
Maybe we could turn down the O.D. of the MC to make it fit?
Yea possibly Ill have a meaure up and see what we can do. Wanting to use the 7/8 m/c if I can as its brand new and has nipples on the right side. I think the 15/16 one would need a rubuild before use as I have no idea on the condition of it. Akaroa is the target but have a lot of things to do to get it there. Will take all the help I can get!
Posted: Wed Sep 12, 2012 9:16 pm
The top and bottom holes look to line up, is there a 720 adaptor like the 610 one? Could you Bore the Adaptor to suit?
Posted: Wed Sep 12, 2012 9:49 pm
by 85_Z31
I installed my Bluebird MC completely DRY and managed to get it bleed up just using a power bleeder on the air compressor. I don't think your going to have any problems, as long as you bleed it first you won't need to go near the bleed nipple. I don't think my Z 15/16th master even has any bleed nipples at all.
Posted: Thu Sep 13, 2012 6:43 am
classicdat wrote:The top and bottom holes look to line up, is there a 720 adaptor like the 610 one? Could you Bore the Adaptor to suit?
That's also what I was thinking Vaughan will see how much needs to come out before it fits in nice and snug
Posted: Sun Sep 16, 2012 5:54 pm
by 85_Z31
Posted: Sun Sep 16, 2012 5:59 pm
by torqued
Nice work guys.
What are you using for adjustment bolts?
Posted: Sun Sep 16, 2012 6:03 pm
James is going to draw something up and we'll get them custom made
Posted: Sun Sep 16, 2012 6:13 pm
by 85_Z31
torqued wrote:Nice work guys.
Datto_610 wrote:James is going to draw something up and we'll get them custom made
its going to be like a normal bolt with a taller head - with a hole in it for the Cap screw/stud for adjusting the camber and toe
Posted: Sun Sep 16, 2012 6:26 pm
by torqued
Sounds like you've got it all sorted.
Good stuff guys
