Garth's SR20 B110
beaver
Re: Garth's SR20 B110
Post by beaver »
Garth wrote:We failed....but on a list so simple i am over the moon :D :thumbsup:
- Rear suspension bump stops (going to have a chat to him about this, not sure hes aware they only have 1 above the diff factory which was there, worst case scenario just install a couple more somewhere)
From memoery the factory shocks would have had bump stops (around the shaft), so you may need to refit some to your current shocks (I take it they have been removed form you above statement)
The single one above the diff isnt really suitable on its own as the diff can rotate and one side bottom out
Garth
Post by Garth »
Kitch wrote:I just put repco belts through mine
Easy , cheap & generic, I know not truly oldschool, but saves mucking around
Yeah might just go for that. I like things being easy and cheap! Cheers team
luke
Post by luke »
i have about 5 you can choose from, mostly tan, about 1984 era, couple black ones. 1972 era.
(may need back if i ever go/finish for cert)
1972 1200 coupe KB110
Garth
Post by Garth »
Anyone have some stock leaves for a 1200? Running into
Some trouble with my setup raising the rear so
Would love to borrow some/buy if I have to
Garth
Post by Garth »
So yeah have cert, reg and wof now. took it to akaroa as some of you would have seen and also took it down south the weekend just been. Loving driving it even though the road noise combined with the fuel pump noise at 100k makes it a pretty uncomfy drive. had some troubles with clutch/gearbox but cheers to Greg I put new slave cylinder in and it seems to have sorted my issues.
anyway heres some pics. Big thanks to everyone who helped out on this build! but as you all know these things are never really finished....
Garth
Post by Garth »
and for some reason these photos have loaded upside down. if you click on them though it loads them the right way up...who knows...
chris_g1
Post by chris_g1 »
Shes legal nice work mate.
