Well you guys already know that my big flash turbo didn't work at all so here is the modified turbo i have been promising.
I really want my car going so I'm less concerned about making power than just having a nice but fairly quick street car
I'm not made of money so i chose to do something to my Factory T3 to improve the flow from the exhaust housing. I will probably have this turbo rebuilt as a t3/t4 at a later date since I already have the t4 front cover and compressor wheel from the turbo which nearly cooked itself.
Step 1 was to hacksaw off the horrendous cast rear elbow > see last pic for an OEM disgusting one
Step 2 was to fully disassemble the turbo so that the turbine housing could be put on a 3 jaw chuck on the lathe
Step 3 is to machine all the crap off the waste gate flange to give us something clean to work with
Step 4 once the waste gate housing was fully machined smooth was to slowly taper the flange outward to the edge
Step 5 was to make up a new flange to bolt on top of the waste gate flange which would allow us to merge the OD all the way out to 76mm or 3" to allow a really smooth flowing rear housing.
Step 6 was to weld a stub onto the new flange to allow for the making of a fully custom high flow down pipe.
Step 7 is to build the rest of the exhaust which I have already done, if you want to see what that looks like scroll up a bit
This is a far superior to a stock t3 and will flow a shit load better without the dog shit rear housing/elbow
300whp should be easily achievable Keep in mind my engine has a performance valve job, Kelford Cams, ported and flowed heads , Nistune engine management 440cc injectors and now there will be zero parts of the exhaust smaller than 3"
and here is the master piece
and compared to a random internet pic of a normal t3 you can see straight away what we have done is going to help a lot
