Cracking along good there Jessee, your work looks great. First time ive had a good read through this thread.
Feel free to hassle me about progress too
ts cup replica b310 coupe
Re: ts cup replica b310 coupe
- tlssunny
- aka: jesse
ok so a little more progress and some photos
front struts, iam in the middle of making the caliper mounts for my wilwood 4 pot calipers to suit the factory 242mm x 10mm b310 rotor
diff, just got it back from royce clive as i got it aligned as had some welding on it etc
it seams to be a h165 diff but someone has welded the b310 mounts on it
-just need to tap the holes to mount the ae86 lsd and make some mounts for the watts linkage setup i have designed and then thats the diff basically done
got a cutting file from bart to do the normal eu13 brake upgrade etc
need to get the ae86 diff and h165 driveshaft made into one driveshaft once i work out the lenght etc
still been working on the rust heaps, have finished the passenger side sill finally with a little bit of help from my friend wal
have now moved on to the rear panel of the car which has been fixed multiple times before so to start with iam basically stripping all the rusted and fucked metal so i can start from scratch etc
wheels, am getting the outer bands made atm and just need to paint the centres a nice bright wheel
-dont know when wheels will be done but iam sure i will have pictures etc
good to see its coming along
- tlssunny
- aka: jesse
a few more pics and a wee update
got my wheels back from powder coating and iam super happy with them, now just waiting on my outer bands to be made
the diff is going good, got the new holes for the head taped and nick welded up all the old ones for me. have dumby fitted it to a half a body i have lying around and its looking all good so i started working on the watts linkage which ive basically done i just need to make the body mounts which will be done this weekend and need some watts arms made too
my front caliper mounts have been designed and now daniel/djz is in the progress of making them
the rear panel iam making is going good, iam waiting on wal to make me a couple of difficult bits then i can get back into it as at the moment iam stuck etc but still have plenty of other shit to do
have basically made 1 good door out of 2 rusty ones, it now just needs some bogg really
James suggested some changes to the caliper brackets which I'll do sometime soon, I've ordered the other end mills I need to make them.
- tlssunny
- aka: jesse
some more photos of mainly the rust work
looking very good, very impressed
what he said. Looking good Jesse. Keep up the good work.
- tlssunny
- aka: jesse
though it was time for a update................
still waiting on the wheel bands to be made but no hurry for me
brought a tyre machine and a shrinker/stretcher so i can stop getting wal to make me a few peices etc thanks for the help wal he made me 2 very difficult peices so i can continue on with the rear soon
i have been mainly working on the front ends of the chassis rails lately and have remade so it looks factory but half way through that now...... theres a few photos of the work. i got some 2mm panel steel so i can remake the reinforcement bits where bumper bolts on
all linkage for the carbs is 95% done just waiting on some shaft collars to show up
have my steering box being rebuilt at the moment, made my own brace for it too
have my ae86 lsd and diff head being rebuilt too once thats done i can basically bolt the diff back together and put inside, just need to sort the handbrake cables really
in october my wife had a wee girl so busy busy with that aswel
half cage is all tacked in so i can work out where everything is going around it, will probly get someone to weld it in as some of my welding aint the flashiest
90% of interior is in etch primer ready for colour later on doen the track, engine bay is basically ready for paint once all front radiator and light support panels are in. just need to finish the inner gaurd peices and then replace some of the passenger side inner gaurd above the chassis rail but i have a mint condition rust cut for this
have modified scuttle panel and bonnet hinges so it will open right up vertical lol
currently working on baffled sump aswel
the peice on the sill where someone has filled it with shit weld and no metal protection will get fixed later on as once the fronts done then i will move back to the back and then to the sill i think
strut brace is almost done just need to make a alloy bar and tap some left and right hand threads in it so its adjustable
at the moment iam waiting on a freind to lathe me up a few bits so i can get onto another few jobs but i dont like to rush him as he needs his holiday etc
heres a few pictures
- gman
- aka: gman
Just a half cage do you intend to race it?
