Re: 2 doors 1200 2door sedan / NOW DRIVING
Awesome! Will be good to see you guys again
Nice work Wal, bet you're fizzing to get on that road trip eh
- aka: Hamish
Where'd you get the new belts from Wal? Are they retractable? I'd like to replace the ones in my ute so they do a bit more than just flap around in the wind
seat belt services on antigua street, they are static fixed non retractable.
Back again , first proper drive on the weekend, sat saw the car at mag and turbo for a wheel alignment, pretty sketchy getting there with 30mm of toe inbut the drive back was great.Sunday I went to the breakfast where I discovered a scratch in the bootlid, turns out I backed into a frame in the yard before leaving home, so my fault, car is running pretty good showing 10 pounds of boost at 3500 rpm but did have a massive backfire when wide open throttle was applied. I noticed though that the backfiring co-insided with the boost guage going off the clock at 20 pounds plus, this led me to looking over the turbo setup ,where I discovered the pipe between the turbo and the actuator was split, I have replaced the pipe but am yet to test-drive to see if the issue is resolved. will report back when test drive has been completed.
pics / vids , stat
Photographic evidence can be seen in this months Breakfast thread
No offence to everyone else but I just want to see this car, not it in a line of others
Here you go Tony
