which has obviously motivated me to get cracking so been getting stuck into the fuel system
So I have brought all my fuel lines, and fittings & mounted up the surge tank and lift pump tonight
Pretty happy with how it all ended up. just have to finish wiring the pumps up, and run the braided
line from the pump to the hard feed line. (this is the only high pressure line, all other lines are just
flow no pressure, and given they are not really seen I went with normal EFI grade rubber hose, this
way it is a bit more affordable, and more the point a lot easier to install).
Here are a few pic's
Tee into top tank retur for overflow from surge tank
