Page 6 of 21
Posted: Mon Nov 04, 2013 8:29 pm
Right. Standard wheels back on, still need new front discs can only assume they will be the same as R30?? Will pop in and see Brock soon. I measured the gearbox the other day so I knew which manual one I needed, short or long. It was a bit difficult to get a good measurement but got somewhere around 750ish mm. My internet research as come up with short box = 668mm and long = 800mm so assuming I didn't quite measure properly I'll need a long box?
Posted: Mon Nov 04, 2013 8:42 pm
by broke
I've had a 3N71 trans on the ground next to a 71B long box and they were the same length, so I'd go with long.
Posted: Mon Nov 04, 2013 8:48 pm
Sweet thanks now the search is on for a long box!
Posted: Mon Nov 04, 2013 8:53 pm
by broke
Have one at home......
Posted: Mon Nov 04, 2013 9:26 pm
I thought the R30 used the short box, and the C31 is the same chassis as an R30?
Posted: Mon Nov 04, 2013 9:28 pm
They don't make a short auto as far as I know which complicates things, it should probably have short box, my old factory manual C31 did. If you try a long box you may find the gearstick is miles away from the hole.
Posted: Mon Nov 04, 2013 10:52 pm
by broke
All good points. You may find (as I did with the C32) that auto and manual floorpans are completely different and the crossmember studs/holes may not line up with either crossmember if you try to do a swap. Brocky and I found a similar issue when trying to fit a LD28 into his R30, neither box would fit.
I know in my case I found a way around the issue, but in Brock's we had to give up.
I recommend taking some measurements before ripping things apart.
Posted: Tue Nov 05, 2013 7:23 am
I'm still a long way off from doing this conversion, I do have the manual driveshaft from the r30 I wrecked so guess I'd need a box to match that length and possibly modify gearbox crossmember?
Posted: Tue Nov 05, 2013 8:27 am
That doesn't sound far off, are you able to compare the C31 Brock has to see what is needed?
Posted: Tue Nov 05, 2013 9:07 am
Looks like I'll be paying Brock and John a visit on Saturday! Hopefully there is still plenty left of the red C31
