Monty's 180b
Re: Monty's 180b
Wider is not always better. I had a wider rear I the sunny and it pushed. Hard to turn in, then swapped ends. Horrible to drive. Reverted to std width and it was much better.
MONTY
Datsun Dreamer
Monty's 180b
Post by MONTY »
Thanks man I was planning on evening out the front but it might just be easier to stick with the original track
MONTY
Datsun Dreamer
Monty's 180b
Post by MONTY »
So I'm not aloud my hyd handbrake for cert so got this rubber tube made so it can easily be swapped out. Also removed the bias controller as this isn't alout to be "driver adjustable"Image
Re: Monty's 180b
What do you need a bias valve for?
IRL, they should be set and forget.
If you want to do meke as skids, fit a line locker.
MONTY
Datsun Dreamer
Monty's 180b
Post by MONTY »
Oh really? I'm guessing someone along the way told me I should use one. Hmmm might leave it out for the mo although it's not much hassle to mount it
MONTY
Datsun Dreamer
Monty's 180b
Post by MONTY »
Another productive day tidied up the fuel stuff in the boot reattached the brake lines in the cabin center consol almost back in, seat out for when I get the new ones in and then a wee play around with the rear travel etc
Pretty much everything other than splitting the gearbox haha
tlssunny
aka: jesse
Re: Monty's 180b
Post by tlssunny »
Bartman wrote:What do you need a bias valve for?
a bias valve will help you setup the correct ratio so you don't have your back breaks locking up way before the front etc I would of thought you would need to use if if changing front and rear brakes and master cylinder etc
MONTY
Datsun Dreamer
Monty's 180b
Post by MONTY »
Thanks tlsunny I'm sure that'll be why I had put it in and also for changing the bias for different surfaces ie gravel :) :) :)
MONTY
Datsun Dreamer
Monty's 180b
Post by MONTY »
Yay more parts arrive. New radiator overflow bottle, sweet deal $36 from a radiator place in aucksImage
MONTY
Datsun Dreamer
Monty's 180b
Post by MONTY »
Don't think I've ever installed something so fast...
Maybe I'm just avoiding putting the gearbox back in
