Started on replacing the sill, was going to keep the center section as it initially looked ok, but it wasnt, pin holes all along bottom once i sanded the paint off, so whole lot came off.
There was some really rough repairs in front of rear wheel, got that all cut out, and there is 2 to 3mm of filler under the vents on the side panel, looks like its had a bit of a hit there at some stage, not sure how far i will go with trying to get the metal in better shape, but want to rust treat it properly as there is a couple of spots where there is rust under the bog starting to push it out.
Ive made the sill up, welded the sections together, and plug welded it on all along, so just need to make the front and rear sections now when i get some more welding gas.
I used a mixture of mig and tig, mig is faster, but can weld 1mm sheet steel butt welds with the tig.
