Its also occurred to me that i havent expressed my full ish plans......
ultimate engine plans will be.....
(factory engine hp is 110hp flywheel)
1994 or below GA16de block
1995 or up head (larger ports). +5hp
reground cams from .342" lift/208" duration to .345" lift/263" duration. +7hp right across the revs.
set timing to 15degrees +5hp mid range +2hp top end UNTIL i get the ecu thing sorted
Reflashed ecu/megasquirt/link/whatever raises the rev limiter from 6800 to 7500. which is when, mixed with the cams, this can produce up to another +40hp between 6k and 7.5k rpm - reduce timing back to 11degrees
Headers - flashy aftermarket ones about +10hp/mine....unknown
exhaust/muffler unknown yet
intake manifold/exhaust spacers from Outlaw Engineering +better running and possible hp
THIS IS ALL WITH THE STANDARD EFI SETUP. STANDARD INTERNALS.(except cams...)
mine will have itbs so unknown what will happen there in terms of hp.
you may all think im being optimistic with all these numbers in terms of hp but iv studied up a lot in the last while due to a lot of spare time being forced apon me, and looked all over the internet trying to find upgrades.
iv got hold of a write up online about a guy that worked one of these ridiculously
.....so proof im not entirely stupid about my hopes in terms of hp.
http://web.archive.org/web/200503052035 ... engine.php" onclick="window.open(this.href);return false;
ACTUAL plans will probably be get it running in the car on standard efi or carbs but with everything there to go efi when need be.
AND FIND A FLIPPING DIFF.
big post but it gives you all something to read and see where i plan to go with this setup. and then if it works il be making another for the ute.
