Luke's 1200 Coupe
Re: Luke's GA16DE Coupe - now has a ute diff, and ute...
front and rear screens if they in good nick? what are you keepiing for yourself?
sedan screen is same as ute,dirtyleppa wrote:front and rear screens if they in good nick? what are you keepiing for yourself?
im not sure yet as condition is not 100% known
1972 1200 coupe KB110
The live plates and tags are a real bonus!
Re: Luke's GA16DE Coupe -list of shit to do before nats
right, my list of things to do before labour weekend (not in order)
600grit wetsand engine bay
paint engine bay silver
spray on more underseal
give john repeated inputs of coin to finish my manifold
get h165, engine xmember, anything else powdercoated black (unless i can just spray paint with clearcoat over?)
bolt suspension back together and fit new bushes to bottom arms
empty inside and fit the ratmat
buy carpet and underlay
fit hoodlining
fit interior
fit all windows
buy brake hoses to go from s13 brakes to factory lines
figure out how to make h165 handbrake work withing coupe
bleed up brakes
fit in engine and gbox
pray
get an engineering firm to cut and weld ute flange to coupe driveshaft or similar thing
get the other john to run new fuel line etc and will hopefully be able to use factory line for a return?
get someone super smart to weld a pump into my spare coupe fuel tank
buy megasquirt or similar ecu
get dan to wire up the thing
h4 upgrade
battery in boot thing
quit drinking so much ($1500 in 3 months......at home)
pray some more
tune
cams reground and refitted
theres probably soooooo many other things iv forgotten to list but thats what you lot are here for.
fit hoodlining
fit interior
fit all windows
bleed up brakes
pray
h4 upgrade
pray some more
tune
Which Labour weekend are we talking 2014 or 2015?....
Stop poking me with that stick, I know I have to get your deadening fitted..clean out the car, degrease / wipe down with mineral cleaner, spray bomb it all so it looks smick... then I will think about coming up to apply it for you!
Kitch wrote:Which Labour weekend are we talking 2014 or 2015?....![]()
how convenient...... coz thats my weekends mission........ that and those damn bottom arm bushes
I think it would be better to do an external fuel pump and under car surge tank than welding your tank up. Pretty much just do what Kitch did on his.
A low pressure lift pump, to an external surge tank, with a high pressure (efi ) fuel pump is tons easier. only downside is, external efi pumps tend to be a bit noisier.
Is the ute diff yolk flange different to the h150 one on your driveshaft?
