Page 55 of 125
Re: Datto_610's 180B - Running Again!
Posted: Tue Aug 27, 2013 8:37 am
by Kitch
talk to the fella at circle track, he subs' out staked joints to a guy in Auckland to get redone.
cost about $170 each from memory.
Posted: Wed Aug 28, 2013 12:00 am
by nick_m
pretty sure circle track just welds washers as mentioned previously, At least a heap of them I have seen previously did. Also heard a rumor technically its not certifiable. They may still be able to stake them like kitch said.
Circle Track are cheaper than MS Coombes by quite a bit last drive shaft we got made was anyway
Posted: Wed Aug 28, 2013 9:20 pm
James took it upon himself to call Justin Neil Engineering for me yesterday to get a price for my driveshaft, is going to be heaps cheaper than MS Combes and can still reuse the parts I already have. Went in and saw Justin today he is going to give me a final price and call me tomorrow. They will be welding washers in as previously talked about and I asked about cert and he said it will be fine. Should be moving on her own power in a few weeks!!
P.s Thanks James!
Posted: Wed Aug 28, 2013 11:06 pm
by 85_Z31
Datto_610 wrote:James took it upon himself to call Justin Neil Engineering for me yesterday to get a price for my driveshaft, is going to be heaps cheaper than MS Combes and can still reuse the parts I already have. Went in and saw Justin today he is going to give me a final price and call me tomorrow. They will be welding washers in as previously talked about and I asked about cert and he said it will be fine. Should be moving on her own power in a few weeks!!
P.s Thanks James!
Haha, no worries, I'm looking forward to the mighty B driving its CA18DET intercooled 5 speed, R200 LSD filled goodness onto the trailer
And i don't want to fix my car on the driveway.......
Posted: Sun Sep 08, 2013 9:48 pm
Intercooler pipes all fitted up and plumbed up cold start/idle control. Had a sneaky run of the engine because I got excited about ic pipes being fitted and after I shut it off noticed oil dripping from the rear of the engine :s could be the rear crank seal lame! Oh well test fitted up the driveshaft loop I got off kitch it's going to need a bit of modding by cutting some of the excess steel off so it fits into the tunnel to work but that's cool. Also tried to play around with my front brake brackets and looks like I'm going to need to grind a smidgen off the steering arm for the bottom hole to line up sigh more issues but still soldiering on!
Posted: Sun Sep 08, 2013 9:50 pm
Should hopefully have the driveshaft back this week too!
Posted: Sun Sep 08, 2013 10:04 pm
by joelbrown
Adding bump steer spacers would probably fix that steering arm fouling on the caliper adaptor,
Unless im mistaken
Posted: Sun Sep 08, 2013 10:57 pm
joelbrown wrote:Adding bump steer spacers would probably fix that steering arm fouling on the caliper adaptor,
Unless im mistaken
I like the way you think Joel, Greg I would be cautious about cutting into a steering are, I can't imagine the Certifier would look to kindly on it. Although I am neither a certifier or ever had a car certed, others would know a lot more than I.
Posted: Mon Sep 09, 2013 7:19 am
I am planning to use bump steer spacers anyway so that could work. But was thinking last night I could swap the struts around and hopefully that will clear everything.
Posted: Mon Sep 09, 2013 8:00 pm
by 85_Z31
Weather you swap your struts around or not, bump steer spacers should be done anyway. Before i fitted them my Z was a bit of a wandery pig, after fitment it was like driving a whole new car.And a bump steer spacer will also help the fact that it only aligns up on the bolts as the center locator's don't touch anything.
I think i found some to suit your struts for about $100 on some website.
