flexis,v bands and turbo flange have been ordered,and my tight radius and donut bends turned up today.
I suspect excessive back pressure combined with a less than perfect oil drain angle didn't help the already 2nd hand turbo that was removed from a big power Sr20.
I'm also taking an opportunity to fit a huge inter cooler and do more direct alloy pipes to replace the " scrap setup i put together to get through cert"
Picked up this specific inter cooler, as it has the easiet shape of end tank for modifying, the inlet outlet will point directly down like some fang's instead of the usual side to side as shown.
If anybody has some experience with a 50mm V band waste gate let me know what you used, I want to keep the 40mm 4 bolt waste gate with my old setup so I can sell it or use it on something else VG30.
