So the white sunny is up on the tard.
Red SGX Sunny should be back on road next week.
Removed front strut assemblies, and fitted new shortened inserts,
and brand new Dobi's, captive by about 20mm
(was hard work to manually compress while I had Karen get the top nut started!)
They are obviously a progressive spring as the pitch varies along the length,
I figure (unfortunately) I will be lifting the car about 40mm
Got some S13 rear cutties to slap in the back and stiffen it up and lift a tad as well
as they are a bit heavier than the 310 stockies
You can see by pic I had got carried away with the avenger spring cutting last effort!
