Posted: Mon Jan 13, 2014 11:27 am
Alrighty my holidays are almost over and I still haven't done anything except rev it up when people come round to visit. Bart was over last night and mentioned I should make a list of things I need to do to finish this thing off. So I did! She's a pretty big list...
*Make fuel filter bracket
*Get new handbrake cables made(mine are pretty rusty and no doubt second hand replacements will be also)
*Rebuild rear calipers
*Run rear brake lines
*Buy and fit new rear C.V boot clamps
*Get new rear springs made (1045lbs)
*Shorten rear shocks to suit
*Finish exhaust system(have my eye on an S13 2.5'' zorst on the tard, also getting a mig welder so might have a go at making my own from that...)
*Mount central locking solonoids
*Re-fit interior
*Mount ECU and relays to kick panel
*Get Dan to make tacho to work with the CA
*Get rear crossmember and front struts crack tested then paint and re-install
*Buy new rear discs
*Install driveshaft hoop - will need some more right angle flat bar as I used some of it for the g-box xmember. Still have the loop part.
*Buy my own tyres
*Attach front guards and grill permanently. Will also need to address the huge dent in drivers side guard at some point....
*Get speedo calibrated. For the moment I'm using my 4.3 R200 VLSD but have a 4.1 that I want to build as a mechanical LSD at some stage so will have to do this again.
*Fix oil leak in diff, just needs the cover removed and threebond used not red rtv.... will do this when rear end comes back out.
*Make a panel to conceal fuel tank in boot.
*Re-bleed brakes once rear calipers and lines are fitted
*Re-fit dash
*Mount horns
*Fit replacement reverse light switch - one on g-box at the moment has the connectors sheared off was like that when I got it.
*May need to shorten speedo cable?
*Mount battery box in boot, either get new cables made that reach boot or lengthen existing ones
*Get fittings welded onto turbo intake for BOV plumback and exhaust side cam cover fitting - eventually run a catch can.
*Plumb BOV into the turbo intake, need 1'' I.D hose.
*Plumb wastegate into I.C piping - will most likely need to strip anodising off and weld a fitting onto I.C pipe. No big deal as I can it re-done for freebies!
*Do a skid!!
*Get wheel alignment
*Go for cert
a) pass and have a big party or
b) fail have a cry sort it then still have a big party
*Drive the dam thing around after 6+ years and debut at Akaroa 2014!
If I have missed anything out don't be afraid to mention it.
*Re-fit interior
*Buy new rear discs
*Buy my own tyres
*Re-fit dash
*Mount horns
*Do a skid!!
*Go for cert
