85_Z31
Posts: 1494 Joined: Sun Jul 18, 2010 10:53 pm
Post
by 85_Z31 » Sat Aug 22, 2015 5:07 pm
Cheers Wal
Went a step futher and Mr angle grinder paid a vist to Mr Bonnet.
This is the result
The reinforcement piece shown below will sit on the underside, this one is just a mock up to see that it will work. 2 Doors is going to make up a set for me ( because im unco and sheet metal is his thing !!)
Bare Metalled the bonnet, I've been spraying the Etch primer in sections. I'm just masking off one area at a time, hand sanding all the little bits of paint i missed with the stripping disck. Then hitting it by hand with 80 grit to key the surface up. Then wax and grease remover with clean cloths. It looks significantly better than what it was.
Posts: 7303 Joined: Sat Jul 19, 2008 9:04 am
Post
by Bartman » Sun Aug 23, 2015 8:20 am
Nice!
brocky41
Posts: 1764 Joined: Sat Jul 19, 2008 11:05 am
aka: Brocky
Post
by brocky41 » Sun Aug 23, 2015 7:48 pm
Lookin good dude,
Will you be able to run the pop up headlight covers at night (do they pop up above them or will they upset the light beam) or just for aero during the day
85_Z31
Post
by 85_Z31 » Sun Aug 23, 2015 8:54 pm
hey brocky , cheers dude
For the light covers they pop up above them but not fully.
the finished set will be clear with maybe the slightest tint to therm so i Don't get in trouble. Ive made them so they are fast to remove.
torqued
Posts: 2125 Joined: Sat Jul 19, 2008 11:49 am
aka: Adam
Post
by torqued » Sun Aug 23, 2015 9:05 pm
You sure you are going to have enough height to not distort the light pattern?
brocky41
aka: Brocky
Post
by brocky41 » Sun Aug 23, 2015 9:16 pm
torqued wrote: You sure you are going to have enough height to not distort the light pattern?
This - be interesting to see it on a light meter - hopefully it doesnt change too much
85_Z31
Post
by 85_Z31 » Mon Aug 24, 2015 11:12 am
brocky41 wrote: torqued wrote: You sure you are going to have enough height to not distort the light pattern?
I hope so too, i really love the look of having the light covers. Its in prototype stage.
D1RTY6
Posts: 223 Joined: Tue Jan 31, 2012 11:48 am
aka: Nathan
Post
by D1RTY6 » Mon Aug 24, 2015 11:15 am
James that looks so awesome! Well done
85_Z31
Post
by 85_Z31 » Mon Aug 24, 2015 10:05 pm
Wof guy said bring it on over to check it out on that machine. He said if it dosnt refract at dodgy angles then it's fine. He said that the Oem headlight itself can't be modified which it isn't.
torqued
aka: Adam
Post
by torqued » Tue Aug 25, 2015 7:37 am
If you have a big board or a wall, you can check it on that.
