Page 8 of 17
Re: Lisa and Brockys TUFDAT 120Y
Posted: Sat Feb 19, 2011 2:58 pm
I work next door to HBI
I saw the mighty yellow beast coming in and out of the car park.
Posted: Tue Apr 12, 2011 4:35 pm
by atchernv
Mint ride - just wondering where you acquired the rear window louvre from, would love to get one for my 120y also
Posted: Sat Jun 04, 2011 10:09 pm
by brocky41
Gday dude - i got this one given to me by my mates grandad thats into his datsuns.
Im sure you can still get them in AUS and they also do venetians
http://www.ebay.com.au/itm/DATSUN-120Y- ... _500wt_715" onclick="window.open(this.href);return false;
Posted: Mon Jul 18, 2011 10:12 am
by brocky41
Next mods on the list for Tufdat -
-Dyna Mat and Carpet
-Strut brace - (modding an r33 one)
-Recaro fishnets (thanks to chris' Bighorn mate)
-Surge Tank - (thanks John (Broke) for modding is up)
Posted: Thu Aug 04, 2011 9:26 pm
by brocky41
Heres the new Extractors - Barts got dibs on the set i dont use, and a pic of the strut brace
Posted: Sun Sep 04, 2011 1:09 am
by brocky41
So the Y spat the dummy at the supermarket - died just going into a park - had to get towed by "Broke" home with the 620 using a small tie down which snapped once (terribly embarrassing in traffic)
Blew a 2nd VL commy (2nd hand) fuel pump so had to fit up the surge tank iv had for ages.
Got a new External Pump and Lift pump from work - all Airtek items - The Vl one is the one listed for Vectras and some Alfa's too.
Decided to filter the fuel from the tank, then into the lift pump, up to fill the Surge tank. I have then mounted a Subaru filter (that i had the bracket for of the WRX STI i wrecked out) to filter the fuel from the surge before the External pump. This will hopefully help keep the pumps in good shape for alot longer. (still running a filter before the engine so TRIPLE FILTERS - what does it mean!!)
Wired it all up and took it for a strop - has never run better.
And also both pumps are very quiet - normally the lift/facet pumps are noisy but these are not - cant here running when car is idling even without back seat.
heres the pics
Posted: Wed Apr 18, 2012 10:13 pm
by brocky41
Gee i havent posted in this thread for a while - Y is again currently off the road - trying to get all the stuff done before the Southern Cruise.
So far ive got it up in the air and the Gearbox out (2nd one to chew bearings due to poor rear gearbox seal)
Uploaded with
ImageShack.us
Got the Turbo box from the 200sx i wrecked out before moving to CHCH going in with new front and rear seals (GENUINE - thanks Scott) and the short shifter fitted. I'm hoping like hell this gearbox is ok.
Also got a new rear main seal from BNT along with some Redline MT90 to go in the box - is an API 1-4 rating as API-5 has some sulphur agent in it that will wear syncros etc (read on the bottle and online)
Next is the front brakes - I have the new rotors which i got a while ago before leaving BNT - getting some new wheel bearings tomorrow - only need the roller part as the shells come already installed in the discs.
Also need new front pads and wheel bearing seals so will sort those tomorrow too.
More stuff to come yet as i stocked up b4 leaving BNT
Posted: Thu Apr 19, 2012 10:22 pm
just a thought on the gearbox rear seals, hows the angle of the driveshaft to gearbox? if its on too much of an angle it can thrash the driveshaft and spoil the seal.
Posted: Thu Apr 19, 2012 11:45 pm
by brocky41
I had thought of that but doesnt look to bad - there was no listing on seals at bnt for the rear box seal but realised this time i had used a honda engine one and their engines spin the other way so was just throwing oil out instead of keeping it in.
Posted: Fri Apr 20, 2012 3:07 pm
Would that mean that the one I got from you a while back is also a Honda one???????
