Beaver's 120y coupe
Kitch
Re: Beaver's 120y coupe
Post by Kitch »
Looking mint!
on my old 1200 sedan, I had the callipers rubbing on the back of the mags too, for some reason it was only really on one side (maybe uneven brake pad wear?) I just ground off about 5-6mm off the offending plate, flap disc ground it back smooth, and painted it black, so was virtually undetectable. no problems ;)
beaver wrote:Ah I think I get you now. Although how will removing material off the inside (where it pushs on the pad) help give room?
Looking good Beaver.
Removing from the inside is easier, the area is smaller and may allow you not to have to cut into the tabs.
I have had a go at drawing on your photo to show where I mean. (please don't laugh, first attempt) The arrow shows where you can take metal from, between the pad and the calliper. The lines show the distance you want to reduce.
beaver
Post by beaver »
Hmm I think I see what you are getting at, still not 100% sure how itl work though. The pad sits in a formed metal bracket type thing which is then attached to the main bracket. Id have to modify this smaller bracket which holds the pad which doesnt seem like a good idea to me.
Unless Im braking up the wrong tree entirely?
brocky41
aka: Brocky
Post by brocky41 »
Cutting bits off brake callipers .......
In all seriousness thou taking about 5mm off the outside will not cause issues.
By the look of the pics cutting from the inside looks hard - outside straight line it, then round her off, paint up, done
Lol that pic is brilliant Brock, Coupe is looking awesome Beaver will be following what you've done if my sister ever wants to slam her one.
beaver
Post by beaver »
found these brakes on tradme (apparently 120y), they look to have less material outside the pad (which is where I am having issues). might just grab them and try them out.....
http://www.trademe.co.nz/motors/car-par ... 646710.htm" onclick="window.open(this.href);return false;
Bare in mind that some B310's were badged as 120y's too. So they could be sunny brakes...........
beaver
Post by beaver »
ah yes good point.
does that mean they will or wont fit mr simpson?
S13 conversion you know you want to :D get it over and done with.
beaver
Post by beaver »
Hah I was actually looking up this morning that swap. Seems to be pretty straight forward.....get a hold of some adaptor plates (Bart, got any left) and some minor machining of the hun to fit inside the s13 disc.
